Disable connection dialing noise when answering FXS
stefan.jones
Hopefully a quick question, but one that is hard to answer by reading configuration guides without better knowing what to look for.
I have an EVM-HD connected up to some analog phones. Whenever one of the analog phones are answered, the router makes dialing sounds for the extention of the answering dial-peer.
It's really obnoxious and I just want to turn off the connection sound.
Any help appreciated!
paolo bevilacqua
Stefan,
do you mean the router is outpulsing digits after it rings the phone, and the user pick-up ? That is very strange because in normal setup all digits are absorbed by dial-peer (pots) used for extensions.
Really one would need to see that configuration.
OIC.
I was copying another's configuration and they had put 'forward-digits all' on all the dial-peers. I'm assuming this is supposed to be only for trunks.
