IP Telephony and Phones
Labels
When users dialled from Norway our vessels and the sat link is down the phone still rings. On the PSTN gateway i n Norway. What do i have to configure on the dial-peer that sends the call to the vessel call manager in order to avoid this perception t...
Morning, I have a customer requirement for SRST across a few sites, with the main aim to provide 100% coverage for all users. I am concerned however around the maximum supported users on the 3825 and 3845. Some of the sites I am quoting for go above ...
i am facing a problem with the cisco ip communicator.The users connect through the vpn and connecting to the callmanager version 4.1.3 the ip communicator version 2.0.1.1is registering and getting the extension number .the problem i am facing is whe...
I am new to the forum.BTW, my cisco AS5350 appear this message on the log and most of the calls drop hv failed. Once i restart the AS5350 for the 1st time, the problem still exist. After 2nd time reboot, the problem solve and all the channels are ful...
woo by Level 1
  • 2890 Views
  • 6 replies
Hi,We have CCM with version 4.2(1) and 300 IP phones. The extension numbers are in the range of 101 - 399. We also have route patterns like 2xxxxxxx, 24xxxxxx etc. for the outgoing calls through the PSTN. So now say from the extension 145 the user tr...
rv_viji by Level 1
  • 321 Views
  • 3 replies
I was wondering of there is any reason not to use the loopback address on a 2821 gateway, I have 2 vwic2-mft-t1/e1 cards and callmanager 4.1.3.There seems to be a debate on whether it is a good idea to use the loopback address or not.Anyone have any ...
miket by Level 5
  • 592 Views
  • 2 replies
I have a customer who is experiencing some annoying issues with thier 7941 phones. When a call comes in, it is automatically answered and goes straight through to the speaker with no user interaction. It is not a user profile issue as the phone can b...
Hi.Has any one tried to setup DHCP on IOS switches or routers? I had as issue providing DHCP to IP Phones via a L2 switch, found that when the switch is rebooted, all DHCP bindings are gone, phones retrieve new IP addresses and fail ro register with ...
