02-22-2012 05:16 AM - edited 03-16-2019 09:43 AM
Hi all, I'm searching a way to disable (and keep the default parameter) the first personalization of voicemail prompted to the user the first time that they access it.
I don't want that my users hear that menu and set some default param like greeting and pin.
Anyone have see this option? I can't find it and I don't know if exist.
Thanks.
Solved! Go to Solution.
02-22-2012 05:30 AM
Uncheck "Set for Self-enrollment at Next Sign-In" from the user main page or template.
HTH,
Chris
02-22-2012 05:30 AM
HTH,
Chris
