Disallow access to cucm-ip:8443/cucm-uds/users and encrypt jabber xml
The goal is to increase security for my CUCM environment with the following 2 points
1- I need to disallow any one to be able to access this URL as it provides all user information details as mobile no.
At the same time, Jabber users should be able to access UDS
2- Encrypt jabber xml configuration file
Is it simply the same way as IP Phones conf files encryption through phone security profile ? or there is another way ?
Haitham
dapo100
Hi Hythim,
Cisco UDS is a simple repository, I am not aware of a way to allow custom access to certain fields of a given directory ( mobile cell phone number field in the user_id record)
You may point your _cisco-uds SRV to a firewall or load balancer, that can intercept the request and via security profiles or iRules to in order to perform the following:
1 - check if the HTTP_REQUEST comes from a Jabber CLient
2. if true, allow connection to CUCM server/UDS url
3. If false, drop connection
As for the .xml encryption, that will be a global Workstation encryption solution for all the files - I imagine the encryption requirement is there not only for Jabber files, so it should not be something UC specific form the service point of view.
