disconnect cause=79 SERVICE_NOT_IMPLEMENTED
hello, I have a problem with international calls, the route pattern is correct, from the CUCM to GTW, I see the call in the GTW, and the marking is correct, it exits the dial-peer correct, but the call is disconnected and gives me busy tone. and the marking is correct, it exits the dial-peer correct, but the call is disconnected and gives me busy tone. this is my dial-peer configuration and debug..... and version the GTW is "c2900-universalk9-mz.SPA.154-3.M2.bin" technology is SIP-Trunk, all calls are less satisfactory international "00"
Jaime Valencia
I hardly doubt a telco will allow a call with an ANI of 4 digits to be placed.
   cisco-ani=7121
BTW, you want to use dialing, not "marking".
There's a spanish area in CSC as well, just click the language dropdown menu in the grey bar.
java
if this helps, please rate
