12-02-2012 08:39 AM - edited 03-16-2019 02:30 PM
Say I have 3 Phones
1001 - Display "HQ1 VoIP Engineer"
1002 - Display "HQ1 Network Engineer"
2000 - Display "HQ2 VoIP Engineer"
Let's say 1001 calls 1002, the phone number and display is correct on 1002. 1002 (HQ1 Network Engineer) decides that the HQ2 VoIP Engineer would be better suited to answer that question so they transfer to 2000.
The display on HQ2 when the call is transferring is correct. But the two callers hang up. 2000 needs to call back the number that was transferred to them (1001), but when he pulls up his received calls, the last number received says ["HQ1 VoIP Engineer" (<----This is correct) "1002" (This is incorrect, this is the number of the person who transferred the call)]
The display on 2000 in received calls should say "HQ1 VoIP Engineer 1001" but instead it says "HQ1 VoIP Engineer 1002." This is exactly the problem I am having right now. Any idea how to fix this? I'm thinking it is something in service parameters.
12-02-2012 11:21 AM
What version of CUCM are you running? Check if you have correct display caller ID configured under each extension.
I have tested it on CUCM 8.0.2.20000-8 and it worked fine. I could see the original caller number and its display name.
R.
12-02-2012 12:02 PM
8.6
12-02-2012 07:24 PM
I believe this might solve your problem
