05-21-2018 01:38 PM - edited 03-18-2019 12:26 PM
Hi!
I need help to find out if it's possible to configure a displayed number eg 5555-551766 (this is a DID configure with num-exp) for outgoing call.
When users make external calls the displayed number is 5555-551700 and when customer wants call back our agents they can use the 5555-551766 number.
I'm trying to fix in 'Calling Party Transformations' in route pattern configuration but it wasn't works.
I put this in the 'Route Patterns' wasn't works.
Next I put this in the 'Directory Number' but still wasn't works.
The version of CUCM is 11.0.1.22900-14
I hope you can help me!
Solved! Go to Solution.
05-23-2018 02:03 AM
05-21-2018 01:45 PM
Make sure you're hitting that RP and debug your GW to find out if you're sending the ANI you want or not.
05-21-2018 02:31 PM
05-21-2018 02:50 PM
Check dial-peer 10 on your GW. Does it have a translation ?
Incoming Leg, the ANI is correct. Once the outgoing leg is created, the ANI is being changed. Attach your router config is possible.
05-21-2018 03:16 PM
05-21-2018 03:23 PM
05-21-2018 03:38 PM
05-21-2018 04:16 PM
05-22-2018 07:24 AM
Yes, I did it
05-22-2018 08:05 AM
05-22-2018 08:41 AM - edited 05-22-2018 08:51 AM
This is my configuration:
R1#show run | section dial-peer voice 31 voip
description **OUTSIDE_TO_CELULARES**
translation-profile outgoing salida
destination-pattern 904[4-5]..........
session protocol sipv2
session target ipv4:x.x.x.x
voice-class sip dtmf-relay force rtp-nte
no voice-class sip outbound-proxy
dtmf-relay rtp-nte
codec g711ulaw
... didn't function
05-22-2018 11:38 AM
05-22-2018 05:47 PM
05-23-2018 02:03 AM
05-25-2018 07:45 AM
