Displaying calling number for outgoing calls !!!!
MdSaifuddin
Hi All,
I have a problem with my outgoing calls. The issue is when making an outgoing call its  not displaying the calling Id for my IP phones instead its displaying the Pilot number but indeed  i want to display an calling id of the IP phones.I cant go with translation pattern as have to follow  my company standards kinly help with an alternate solution.
Using the PRI E1 with MGCP protocol.
Aman Soi
Hi Saifuddin,
Do you have DID facility on Voice E1 PRI?
Can u share the config of Router?
regds,
aman
MdSaifuddin
Hi Aman,
I do have DID range on voice PRI E1.
Will you tell what exactly needed from router configuration ?
Hi Saifuddin,
Can u check below two points under  Call Routing Information -Outbound Calls in MGCP Gateway configuration on Call Manager side since you have MGCP?
Calling Party Selection [Should be Originator] and calling party Presentation[should be Allowed instead of Default]
regds,
aman
islam.kamal
Level 10
Level 10
Dear
For outgoing call , you will use DOD .Firstly you have to check with your ITSP that they will ok to allow your DOD.
what you need that  (you will have ext 2001 , you will need to show it for outgoing call 78999992001). It is so eazy.
you have to create CSS outgoing calling id for exampl (HQ-callout)
1- Go to each phone and go to DN >external phone number  mask)
Call   Routing > Transformation -> Transformation Pattern -> Calling   PartyTransformation Pattern - See more at:   https://supportforums.cisco.com/docs/DOC-27492#sthash.ZcJN3DAf.dpuf
and type for example 78999992xxx (where 2 is the start digit and xxx represents the last three digits).
2-go to call routing > Transfomation>Transformation pattern>calling party transformation pattern
3-enter yor roue pattern for the outgoing calls which you have created before (9.!) ,enter the css
(HQ-callout) then under calling party information
check ( use calling party's external phone number  mask)
4- on the gateway
a. Go to Device -> Gateway, look for the MGCP device and under
         “Call Routing Information - Outbound Calls” look for “Calling Party Transformation CSS”,
          configure there the Calling Search Space we created =Transformation_CSS .Uncheck the “Use Device Pool Calling Party Transformation CSS”.
b. The other workaround is to Go to the configuration page of the MGCP
gateway in CallManager, under “Call Routing Information - Outbound Calls”:
c. Look for the parameter: “Number of digits to strip” and set it to 1.
This way the CallManager will remove the 9 for all any outbound call, however for normal
calls IP phone to PSTN it will also remove the first digit so you can configure a 1 in front of
the “External Phone Number Mask” in the line settings.
d. Set the “Caller ID DN” as XXXXXXX (x = same amount of digits of your External PhoneNumber Mask),
Other solution
Kindly check the below image   , you can edit the route pattern .
Thank you
please rate if this will help
