DTMF ISSUE WITH SIP TRUNK FROM PABX TO GATEWAY
vikas_ruhil
                   Hi ,
I have a gateway connected to a PABX via sip trunk. Gateway is connected to another site which has an IVR. The protocol from my gateway to IVR is H323. Now when i place a call from PABX to IVR. DTMF doesnt work. I have tried making all dial-peer DTMF-RELAY RTP-NTE. But still it doesnt work.
When I ask the customer they say they are supporting RFC2833.
The following is my configuration Dial-peer 10 and 55 point to my IVR (malasiya), sip dial-peers point to PABX in singapore site (my current site):-
dial-peer voice 10 voip
destination-pattern .T
session target ipv4:183.81.244.248
dtmf-relay h245-alphanumeric
codec g729r8 bytes 40
fax-relay ecm disable
fax rate 14400
ip qos dscp cs5 media
dial-peer voice 55 voip
destination-pattern 001T
incoming called-number #
dial-peer voice 1 pots
answer-address 11
destination-pattern 88606[1-8]...
dial-peer voice 2 pots
answer-address 11
destination-pattern 88655[1-8]...
dial-peer voice 3 pots
answer-address 11
dial-peer voice 4 pots
answer-address 11
dial-peer voice 5 pots
answer-address 11
destination-pattern 88655[0,9]
forward-digits 1
dial-peer voice 6 pots
answer-address 11
forward-digits 1
dial-peer voice 7 pots
answer-address 11
forward-digits 1
dial-peer voice 8 pots
answer-address 11
forward-digits 1
dial-peer voice 100 voip
description *** CALLS TO IP PBX TEST ***
translation-profile outgoing 9to4
destination-pattern 88606....
session protocol sipv2
session target ipv4:172.27.31.10
voice-class codec 10
dtmf-relay rtp-nte
no vad
dial-peer voice 101 voip
destination-pattern 88606[09]
dtmf-relay rtp-nte
no vad
dial-peer voice 102 voip
destination-pattern 88655....
dtmf-relay rtp-nte
no vad
gateway
timer receive-rtp 1200
emulate cisco h323 bandwidth
voice-card 0
dspfarm
dsp services dspfarm
voice call send-alert
voice rtp send-recv
voice service voip
ip address trusted list
  ipv4 172.27.31.10
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
  bind control source-interface Loopback10
  bind media source-interface Loopback10
  header-passing
  history-info
voice class codec 10
codec preference 1 g729r8
codec preference 2 g711ulaw
fax rate 14400
answer-address 11
answer-address 11
answer-address 11
answer-address 11
answer-address 11
forward-digits 1
answer-address 11
forward-digits 1
answer-address 11
forward-digits 1
answer-address 11
forward-digits 1
dtmf-relay rtp-nte
no vad
dtmf-relay rtp-nte
no vad
dtmf-relay rtp-nte
no vad
gateway
voice-card 0
dspfarm
voice rtp send-recv
voice service voip
  ipv4 172.27.31.10
h323
sip
  header-passing
  history-info
Ayodeji Okanlawon
Vikas,
Configure the following on your sip dial-peer towards PBX
dtmf-relay rtp-nte digit-drop
dial-peer voice 102voip
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
