04-08-2010 02:48 PM - edited 03-15-2019 10:10 PM
After a call is connected if you press any of the number keys the numbers do not display. Is there a setting in call manager to turn this on? I have gone through the admin and system guide and have not found a reference to this.
Thanks in advance.
Solved! Go to Solution.
04-08-2010 03:28 PM
Unfortunately that's not something you can configure. Once the call is connected the DTMFs are sent but they won't show up in the LCD screen after the DN you dialed.
If you feel this should be a feature, get in touch with your AM and ask him about submitting a PER on this.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
04-09-2010 12:13 AM
I had this request once; there was no way to do it then, and I'm not aware of anything changing since...
You see the dialed/connected number, not the DTMF you send afterwards...
Aaron
04-08-2010 03:28 PM
java
04-09-2010 12:13 AM
Aaron
