DMA tool and CUCM 8.0(2)
cae_technology
Customer has 4.X. we are going to migrate  and install  version 8.0(2) on new servers, (6 in total)  looking at the DMA notes, the latest DMA version is for 7.(1). So If i collect DMA File from 4.x and load onto version 8.0(2) server, will it work? or do I need to be on 7.1 first and then upgrade ot version 8.0?
I assume I only need to run DMA on the Publisher?
Rob Huffman
Hi Support,
There is no direct upgrade path between any 4.x CCM to
CUCM 8.x as shown below;
Table 4     Supported Cisco Unified Communications Manager Upgrades for Release 8.0(x)
8.0(3)
8.0(2c)SU1
8.0(2c)
8.0(1)
System Version
8.0.3.10000-8
8.0.2.41900-3
8.0.2.40000-1
8.0.1.10000-40
Release Date
Jul 27 2010
Jul 8 2010
May 6 2010
Feb 26 2010
Standard Support
Direct upgrade:
8.0(2c)SU1, 8.0(2c), 8.0(2b), 8.0(2a), 8.0(2), 8.0(1), 7.1(3b)SU2, 7.1(3b)SU1, 7.1(3b), 7.1(3a)SU1a, 7.1(3a)SU1, 7.1(3a), 7.1(3), 7.1(2b)SU1, 7.1(2b), 7.1(2a)SU1, 7.1(2a), 7.1(2), 7.0(2a)SU3, 7.0(2a)SU2, 7.0(2a)SU1, 7.0(2a), 7.0(2), 7.0(1)SU1a, 7.0(1)SU1, 7.0(1), 6.1(5)SU1, 6.1(5), 6.1(4a)SU2, 6.1(4a), 6.1(4)SU1, 6.1(4), 6.1(3b)SU1, 6.1(3b), 6.1(3a), 6.1(3), 6.1(2)SU1a, 6.1(2)SU1, 6.1(2)
Direct upgrade:
Direct upgrade:
Direct upgrade:
Direct upgrade using DMA:
none
none
none
none
From this excellent doc;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/ccmcompmatr.html#wp184796
You would have to complete a "two-hop" upgrade to 6.x or 7.x as an intermediate step as you nicely noted
FYI - many people are holding off going to CUCM 8.x due to the number of bugs.
Cheers!
Rob
Rob Huffman
Hi Support,
8.0(3)
8.0(2c)SU1
8.0(2c)
8.0(1)
System Version
8.0.3.10000-8
8.0.2.41900-3
8.0.2.40000-1
8.0.1.10000-40
Release Date
Jul 27 2010
Jul 8 2010
May 6 2010
Feb 26 2010
Standard Support
Direct upgrade:
Direct upgrade:
Direct upgrade:
Direct upgrade:
none
none
none
none
Cheers!
Rob
Thanks Rob,
It was just as I suspected.
I have also seen that 8.0 has not been the success, that Cisco hoped for, but I thought 8.0(2) was more stable. Is that not the case? I wanted to avoid 8.5
as it was early days on that release
Rob Huffman
Hi Support,
You are most welcome my friend
The 8.0(x) builds have been pretty sketchy as is the nature
of most if not all .0 builds. I would not move towards any 8.0
version. The consensus on these boards seems to be that the
most stable current build is 7.1(3b)su2.
I would give the 8.5(x) version at least 45-60 days on the market
to see how things are working and for Cisco to release any ES's
for initial critical bugs.
Just my thoughts.
Happy Holidays!
Rob
