07-26-2016 09:28 AM - edited 03-17-2019 07:38 AM
hello,
is it possible to use one DN in two Hunt groups ? I want my DN to be a member in two Hunt groups!
Can anyone help me?
cheers
Markus
Solved! Go to Solution.
07-26-2016 09:40 AM
Yes, add the DN to the desired line groups and assign the line groups to hunt lists. Point your hunt pilot at the hunt list.
Brandon
07-26-2016 09:40 AM
Brandon
07-29-2016 03:02 AM
thx for replay!!
Cheers
Markus
11-04-2019 05:31 AM
how do you toggle between HGs (when the phone is a part of 2 or more LG/HP) using HLog softkey?
Or does HLog just toggles between Login/Logout?
