DND on CME Question
mlitka
Level 2
Level 2
How does the DND feature work on CME? Does it simply silence the phone and let the CFNA timer expire and then foward to CFNA destination or should it bypass the CFNA timer and send the call to the CFNA destination immediately?
Chris Deren
It simply silences the ringer and lets the timer expire. If you want the call to go to VM immidatelly then you would engage callForwardAll and press Messages button.
HTH,
Chris
Chris Deren
HTH,
Chris
