DNS SRV Redundancy
Hi everyone,
I'm working with two CME(CME 1 and CME 2) supporting all our phone in a active/stadby redundacy scheme. We need to have a redundacy for our thirdparty phone (X-lite, YeaLink...) to register with CME 2 when CME 1 be down. For this scheme we're trynig to use DNS SRV to setup at all thirdparty phone the SIP server name as cme.lab.local, if CME 1 is down, phone should be able to know it and be able to register with CME2.
Right know, I'm able to resolve cme1.lab.local and cme2.lab.local but isn't working when I try to resolve cme.lab.local as my SIP server name. Here my configuration:
ip domain name lab.local
ip name-server 127.0.0.1
ip dns server
ip domain-lookup
ip host cme2.lab.local 192.168.6.14
ip host cme1.lab.local 192.168.6.10
ip host cme.lab.local srv 1 25 5060 cme1.lab.local
ip host cme.lab.local srv 2 25 5060 cme2.lab.local
Result:
ADSL-CubeCUCM#ping cucm1.lab.local
Translating "cucm1.lab.local"...domain server (196.3.81.5)
Sending 5, 100-byte ICMP Echos to 192.168.6.10, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
ADSL-CubeCUCM#
ADSL-CubeCUCM#
ADSL-CubeCUCM#ping cucm2.lab.local
Translating "cucm2.lab.local"...domain server (196.3.81.5)
Sending 5, 100-byte ICMP Echos to 192.168.6.14, timeout is 2 seconds:
ADSL-CubeCUCM#
ADSL-CubeCUCM#ping cucm.lab.local
Translating "cucm.lab.local"...domain server (196.3.81.5)
% Unrecognized host or address, or protocol not running.
As a reference it's use this guide: http://ben.thepolzins.us/2010/02/06/using-dns-srv-records-with-ios-dial-peers/
Any help would be appreciated
Please rate all useful posts
Favor calificar todos las respuestas útiles.
_____________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
MDGDP, CCNA, CCNA Voice certified
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
2 Accepted Solutions
Your srv config is not correct. You define SRV records with the protocol its going to use either tcp or udp as shown below
ip host _sip._udp.cmgroup1.lab.local srv 1 50 5060 cucm1.lab.local
ip host _sip._udp.cmgroup1.lab.local srv 1 50 5060 cucm2.lab.local
ip host _sip._udp.cmgroup1.lab.local srv 1 50 5060 cucm3.lab.local
or for tcp
ip host _sip._tcp.cvp.cisco.com srv 1 50 5060 cvp4cc3.cisco.com
ip host _sip._tcp.cvp.cisco.com srv 1 50 5060 cvp4cc2.cisco.com
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Leo,
Glad I could help. Out of curiosity why the 4 stars for a correct answer?
9 Replies 9
Ayodeji Okanlawon
Your post does not show that you have defined the SRV records....Have you done this?
@aokanlawon, thanks for the response. I thought these lines command should be the SRv record:
Am I missing something?
or for tcp
It work like a charm!
Just need a little help from this two command:
Windows: ipconfig /flushdns
Router:clear host all *
A important note: Some softphone/ IP phone doesn't support DNS SRV Failover (but DNS SRV is supported) so for test porpuse you will need to reset the phone.
Leo,
Chrome didn't let me choose Correct Answer or select the star, that's weird...I'm back to Firefox...
Thanks Leo! Hahaha the highly advertised and rated Chrome is the culprit.
iptuser55
Level 6
Level 6
I'm trying to do the same but can not enter in the commend you highlighted
ip host_sip._udp
Is it IOS SW level related as it will not let me do so
thanks
If you cant see the commands, then its most likely your IOS doesnt support it
