08-11-2009 11:52 AM - edited 03-15-2019 07:18 PM
hi! we have a T1 CAS circuit (on 2821 MGCP GW) went down but came up shortly. But the problem is on CallManager, under Gateway configuration, the end point associated with this T1 is
Registration: Unknown
and there is snmp trap:
Message: snmp trap ccmGatewayFailed
1.should we have to perform"reset gateway" at end point level (not the whole router reset)
2. is it normal MGCP behavior?
08-11-2009 12:34 PM
I would check the MGCP gateway's name and make sure it matches exactly with Call Manager. If the names do not match exactly, it will never register.
08-11-2009 12:38 PM
there are other ISDN PRI on the SAME router and they are all registered with CM properly. and there is no change on hostname and domain.
It seemed the GW is not trying to register with CM for this T1 after it's up again.
08-11-2009 12:41 PM
If you do a "sh isdn stat", does that T1 that went down show "mulitple frame established"?
08-11-2009 12:44 PM
but it's not PRI isdn. it's T1 CAS
08-11-2009 12:48 PM
I apologize...can you attach a sh run?
08-11-2009 01:18 PM
A couple things to check:
-Does the pots dial peer for the CAS circuit have 'service mgcp' under it
-Does 'show ccm | i Name' match what you've defined in CUCM
-Do 'show voice call summary' and 'show voice port summary' show that the T1 is idle and up?
-Is 'show controllers t1' showing the controller up?
Otherwise, 'debug mgcp packet' may be helpful.
-nick
08-11-2009 01:25 PM
from CM, I "reset gateway" on this T1 only. Now this T1 is registered with CM.
but this is not normal. The GW is not trying to register with CM for a T1 that has been restored..
Aug 11 17:11:00.451 EDT: %LINK-3-UPDOWN: Interface recEive and transMit0/0/1:1(24), changed state to up
GW#
Aug 11 17:11:08.059 EDT: %CMAPP-6-CONFIG_DONE: Configuration by CCM is done
08-11-2009 02:37 PM
Hi Eric,
It would most likely be because the T1 was in a bad state, which is why you would want the show commands to see which state it was in.
"Only from CUCM" is very misleading. When you do this, it re-configures the voice ports and shuts/no shuts them via TFTP. So you only touch CUCM, but you're still resetting things on the gateway.
-nick
08-12-2009 05:17 AM
no. this T1 CAS was fine because later we were able to make LD calls and debug vpm signal showed activities.
yes. you're correct CM just instructed GW to reset the T1.
my concern now is that if it takes manual reset to register the T1 to CM, is it a normal behavior?
08-12-2009 02:06 PM
No it's not. I would get the show commands and open a TAC case if necessary. If you're on the latest version you'll get less hassle, because there's a pretty good chance someone will ask you to reproduce it on the latest version.
-nick
08-12-2009 02:16 PM
Yes. I opened TAC case and TAC is looking into it.
08-12-2009 02:14 PM
Why don't you take the easier route and use H.323 instead.
You will find that it works more predictably and has more features than MCGP.
MGCP was invented to shift intelligence from gateway to server, unfortunately in the cisco implementation it seems like the intelligence has been lost during the move.
12-02-2013 11:20 AM
We have encountered a similar issue, what were TAC's findings and conclusion on this issue.
Thnaks,
VV
