10-22-2016 09:27 AM - edited 03-17-2019 08:26 AM
I seem to be able to configure a quote for a single CUWL Standard license with a 1 user subscription for a single user for CUCM 11.x
Does this mean that if I purchase this, I will also be able to download the CUCM 11.x software ?
Different CUWL docs seem to say different things.. Most say software is included, but say a minimum of 25 or 50 users is required.
So if I order just a single user, I am not sure if I will still be able to get the software as well ?
10-22-2016 10:29 AM
AFAIK if system is allowing you to order just 1 user then the media should be there as well. However, it will be good to post your question at below forum for a definite answer:
http://www.cisco.com/c/en/us/partners/support-help/presales-helpline.html
Deepak
10-22-2016 01:29 PM
Thanks, but I guess that link is only for Cisco Partners (which my CCO ID used to be associated to, but not any longer),
I guess I can try contacting a local re-seller as well, but in my (limited) past experience, unless you are a large customer, they expect you to give them the exact part numbers 😞
10-22-2016 06:31 PM
Yes you are right that link is for partners only. You can try contacting your local reseller and see if they can help else wait for some time and maybe someone on community can help you with this who are involved more in ordering these things for their respective company.
Deepak
