Does fax function support transfer by Auto Attendant
yun zhang
Hi  Guys
I have a question about fax transmission , our client ask me that they have a voice gateway with 2 fxo and 1 fxs card , the fxo  port connect to pstn and fxs port connect to fax machine (extension 3333). the auto attendant function is setup in the unity conenction . The question is when a user call their main number by fax machine via pstn then user heared welcome voice by auto attendant and dial 3333 to transfer to fax number . Does this function can be realized is the senario ?
following  are senario diagram
fax machine -- pstn ---- fxo port (cisco voice gateway ) ------- switch ------(callmanager unity connection)
                                                    fxs (fax machine)
Thanks in advance
support
Yes , it will .
You can forward FXO to callmanager unity connection . Inside callmanager unity connection forward 3333 to Voice gateway as an SIP connection .
Note: Always buy ATA instead of FXS card . Will solve many problem like this automatically .
Claudion .
I do not recommend to buy Cisco ATA. Cisco ATA 186/187 is full of firmware bugs, maybe newest version Cisco 188 it could be better.
__________________________________________________
Please remember to rate useful posts clicking on the stars below.
LinkedIn Profile: do.linkedin.com/in/leosalcie
Thank you
Many Thanks
