Hi everyone, I have created translation rule for manipulating PSTN digits to internal extension. So it's being used for DID. Now same time we want clid to be prefixed with digit 9 also. Any clue to do it CME?
Hi guys,We have a SIP trunk with Colt Telecom in the UK. We don't have a router as CUBE, the SIP trunk is terminated directly on the CUCM. Telco or restrict the outbound caller-ID to a 11-digit number assigned to the SIP trunk. The external phone num...
HI CiscoMay i have an advice regarding about CUCM integrate with SIP Gateway? Currently Service Provider want install CUCM for their customer. Its mean their customer phone directory number will register inside CUCMOutbound Call from customer to PSTN...
I am new to VoIP. I acquired several SPA504G phones and a 2811 router. I want to setup a basic VoIP lab environment with this equipment. I have interface Fa0/0 on the router connected to a basic 8-port switch, and a couple of phones connected to the ...
Hello, i have call flow of PSTN with fxo card: CUCM>>>>MGCP>>>>FXO>>>>>PSTN when getting incoming calls, it is connecting correct...but in outgoing calls, as now all international calls showing connected over IP Phone but it is not connecting to call...
Hi,I am new to this. I am looking for a step by step procedure upgrade my voice routers, 2801 voice router with CUE 3.2 to 2901 ISM.Is there a guide to do this please. I need to upgrade several voice routers. Thanks in advance -
Hello, Below is the problem description; "We have a couple users that are experiencing contact conflicts within Jabber. As you can see from the below image, the contact is actually Bob Smith, however once and a while different contacts will appears a...
Can some one help me to upgrade an 8831 directly? I am struggling to browse to the device. We are trying to use it on a non cisco system as a SIP conference phone.
Hello,I've enabled Web Access via CUCM for an ip phone but I am still unable to hit the Web UI for the phone. I've tried HTTP and HTTPS. I've also tried selecting the override system defaults check box next to HTTPS server but still no luck. Anyone e...
Hello, I'm working for a client who has an extension that is used for anonymous call ins. They need to have it so that not even caller ID shows up for this phone. I have not found a way to do this per DN. There are plenty of ways to do it for outboun...
Hi i have a Cisco BE6000 Server and i want to power it when connected to the power alimentaion , And did not see power management option in The BIOS, Can Some help me on that ? Is it possible to do that wit BE6000
my customer currently environment is using CM and CUC v8.5, and going planning to upgrade to v10.6, they planning to have some CUWL STD user and some are Enhance, they have 980 users have phone and CUC license and 200 users have phone license only. ...
Hi, I am using Cisco CallManager version 10.5. Is it possible to Transfer the call when the Call is On Hold. Thanks,Ramesh
Hi, i have remote destination configured on my cisco ip phone registered on the CUCM 10.5.When i have remote destination enable on my hone i receive the call directly to my mobile phone but with an incorrect caller id.The CUCM is in France and the in...
Hi,I have deployed CUBE on a 2921 running IOS 15.3(1)T to link a CUCM 8.6 cluster to an ITSP (Gamma Telecom in the UK).The ITSP sends/receives calls using G711alaw. This is fine for standard voice calls to IP phones (7940 and 7960) as they support th...
| Subject | Author | Posted |
| 03-04-2026 06:20 AM | ||
| 03-02-2026 07:40 AM | ||
| 03-02-2026 07:34 AM | ||
| 01-16-2026 03:24 AM | ||
| 12-31-2025 01:52 PM |
