Does ISR 4321 support VWIC2-2MFT-T1/E1
@Syed
Level 3
Level 3
Dear All,
Very quick question here.
Can you confirm if the VWIC2-2MFT-T1/E1= card will be supported on the ISR 4321 series router.
Leo Laohoo
It won't work.  The physical dimension and the connectors are all different.  The replacement is NIM-2MFT-T1/E1.
7 Replies 7
Leo Laohoo
Thank you for your quick response.
Can I take it as confirmed answer, because I am going to generate BOQ for my customer.
If you need an actually written (and "airtight") guarantee, then talk to Cisco TAC.
I will do that, but accordingly it won't.
Thank you
Forgot to ask you.
how about VWIC3?
Same answer:  It won't fit & it won't work.
However, I have something that'll make your customer smile:  Get a FREE Cisco ISR 4331
Jaime Valencia
There's a whole page dedicated to compatible modules with the ISR 4000 series
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
java
if this helps, please rate
