Does SIP on the cisco gateway 2901 required DSP PVDM channels
obaidabdullah
Hi everyone
i have cisco 2901 and i have sip line configured on it from sip service proveder
the sip line have 30 DIOD channels so does the sip use the dsp PVDM
Chris Deren
No do you not need PVDMs unless you require transcoders for whatever reason in which case PVDMs are the only way to build transcoders.  An example of required transcoders might be calls arrive from SIP provider as G729 yet you have UCCX application installed as G711. Another example might be calls arrive as G711 and need to be delivered to remote location as G729.
HTH,
Chris
