06-27-2013 11:57 AM - edited 03-16-2019 06:07 PM
Client is upgrading from CM 4.0 to the BE6K 9.1. He wants to keep the old phone. Does the BE6K support the 7940 and 7960 phones?
06-27-2013 12:57 PM
Absolutely supported, in fact Cisco never decommissions any old phones, they may not have recent firmware load nor get any further code releases, but the phones continue to be supported to be registered with CUCM.
HTH,
Chris
06-27-2013 01:36 PM
I'd recommend you to review this, Dan explains it quite nicely
https://communities.cisco.com/thread/35948?tstart=0
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
