03-05-2015 06:36 AM - edited 03-17-2019 02:13 AM
I have to use dotx and mda with a nps Windows server and non-Cisco phone but Cisco switch (cause I have a PC connected behind a phone and both must be authenticated).
I've succedded as my phone and my pc connected behind the phone suceed authentication and authorization and a "show authentication sessions" show me that authentication is right in domain DATA and VOICE.
But a few minutes after, there is port violation beacuse the phone (yealink) try to authenticate again and fails this time (while it had succeeded the first time...)
I really does not understand what can happen and why it's ok a frist time and ko few minutes later...
Thank you for your help!
03-16-2018 05:23 AM - edited 03-16-2018 05:24 AM
Hi @david.gras
The port of your cisco switch is like this?
interface GigabitEthernet1/0/XX
description IP-PHONE&COMPUTER
switchport access vlan 21
switchport mode access
switchport voice vlan 20
authentication host-mode multi-domain
dot1x pae authenticator
spanning-tree portfast
spanning-tree bpduguard enable
Do you check this cisco dicumentation?
03-16-2018 06:21 AM
