08-10-2009 04:17 AM - edited 03-15-2019 07:17 PM
My Customer have a gateway model 2801 with 03 analogical lines in fxo interface that are using ro send and receive by pstn.
In this topology there are IP Phone too. My question is: It's possible that a one specific directory number to do call only
by interface 02 fxo?
Wilson Santana
08-10-2009 04:25 AM
Please provide more information on the protocols and call agents that you are using. It cannot be determined from the information provided.
-nick
08-10-2009 04:30 AM
Hi Nick,
My Customer is using mgcp, the CallManager is version 5.1.3
Wilson
08-10-2009 05:21 AM
Yes, CSS and partitions
Create route patterns associated to that FXO and make sure only that phone can reach it.
java
if this helps, please rate
08-10-2009 09:54 AM
08-10-2009 10:07 AM
Could you please post the confi in .txt format, I cant install the WinRAR on my machine (and so do I think of many others)
Wilson Samuel
08-10-2009 10:09 AM
Hi Wilson,
I didnt understand your question pretty well?
If I understand correctly, all you want is the branch office wants to go to the PSTN using the FXO card and would also like to recieve/make calls on that the FXO card.
If yes, then you have to configure things on the CCM, in order to make it work.
Wilson Samuel
