Doubt about difference configuration CSS in Physical and Line
wilsonsant
Level 6
Level 6
Hi Guys,
I would like know what the difference when configuring CSS in physical and Line. Physical is about call enter and Line is call out? Is this?
Wilson
Hi Wilson,
line CSS takes precedence over the device CSS, but final destination is decided reachable or not after a concatenation of both.
See below for better understanding
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-communications-manager-callmanager/22325-part-css-tn.html
Also see
http://ciscovoicevirtuallab.blogspot.in/2014/12/css-line-device-approach.html
(Rate if it helps)
JB
Jitender Bhandari
Hi Wilson,
Can you explain what do you mean "in physical" do you mean on phone?
Are you looking or difference between Device \ phone and line CSS?
JB
Hi Jitender,
Thanks a lot for Your contact. Whe I told in physical, is related the same page where I put the MAC Address.
Wilson
Hi Wilson,
Also see
(Rate if it helps)
JB
Jaime Valencia
Read this, as you don't understand the basics of CSS and partitions
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/8x/uc8x/dialplan.html#wp1044276
java
if this helps, please rate
