06-15-2011 10:37 AM - edited 03-16-2019 05:28 AM
Hi Guys,
I have the following doubt: Is it possible to do the channel selection order when work H323 protocol? I know that when using the MGCP is possible configure in the CCM the order the channel ocupation (Top and Down), but, in the CCM not exist the option to H323? Is there this option in gateway?
Wilson
06-15-2011 10:41 AM
HI Wilson,
Yes you can configure under serial interface:
CME-INT(config)#int ser 0/1/0:23
CME-INT(config-if)#isdn bchan-number-order ?
ascending B-chan selection starting from B1
descending B-chan selection starting from B23/32
Vandana
06-15-2011 11:11 AM
Hi Vendana,
My Customer have 02 E1 and work with R2 Digital (not ISDN).
Wilson
06-15-2011 11:42 AM
H.323 in itself does not select any channel.
What is wrong with the default ?
06-15-2011 12:00 PM
Hi Bevilacqua,
The Customer informed to Us that the three first channel about E1 not is been occupated. If H323 had this possible I will invert the selection in conjunt with the carrier and verify the problem continues.
Thank,
Wilson
06-15-2011 12:29 PM
Sorry, I do not understand. You need to look at traces not what customer says. If the channel are not being used that is not a selection order issue.
06-16-2011 08:01 AM
Hi Bevilacqua,
I am sorry by delay. I interviewed again my Customer and He told me that the problem is another. After user finish the call, the channel stay busy and return available only restart the channel.
Wilson
06-16-2011 09:54 AM
That is what I was thinking.
Try updating IOS.
