06-28-2010 10:37 AM - edited 03-15-2019 11:27 PM
From where can I download htis file cue-vm-license_12mbx_ccm_ise.7.0.3.pkg ?
I need to download this file but I don't find it in Cisco. Somebody can help me?
06-28-2010 11:08 AM
Hi there,
Here is the path
Voice and Unified Communications > Unified Communications Applications > Voice Mail and Unified Messaging > Cisco Unity Express Version 7.0 > Unity Express License Packages > 7.0.3 > cue-vm-license_12mbx_ccm_7.0.3.pkg
Cheers!
Rob
Please support CSC Helps Haiti
06-28-2010 11:16 AM
thanks rob but I'm looking for specifically for 1861 ISE module, in the part that you say me there is valid license file for ISE module.
06-28-2010 12:06 PM
Hi there,
Sorry about that, it would help if I could read
Are you sure about that Part# I don't believe that it exists
and that is why you are having trouble finding it for Download. I don't
think these License upgrade/addition files will be supported on the 1861 ISE.
Cheers!
Rob
06-12-2013 09:01 AM
Please check with this link:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity_exp/rel7_0/install/upglic.html#wp1147999
