dps resources, how to determine
sarahr202
Level 5
Level 5
Hi everybody.
Several voice gateway routers require dps resources to convert analog call to voip and vice versa. Are these dps chips come with the cards such as fxo or do we have to order it separately ?
thanks and have a great day.
2 Accepted Solutions
Harmit Singh
Hi Sarah,
DSPs are embedded onto PVDM modules which fit onto the motherboard of the router or on network modules such as NM-HDV2. Depending on the model of the router, the number of PVDM slots vary. Depending on the part number of the PVDMs, the numbers of DSPs and density varies. Here is a link which should help address some of the follow up questions you may have:
http://www.cisco.com/en/US/partner/prod/collateral/modules/ps3115/qa_c67_553073_ps10537_Products_Q_and_A_Item.html
If you need more info, feel free to reach out to me.
HTH.
Harmit.
Just realized the link may not work for you. Try this one:
www.cisco.com/en/US/prod/collateral/modules/ps3115/qa_c67_553073_ps10537_Products_Q_and_A_Item.html
Harmit.
Harmit Singh
Hi Sarah,
HTH.
Harmit.
Harmit.
