Fax solution recommendation
Robert Craig
Level 3
Level 3
I know many people ask this and it's results are back and forth, but I wanted to get everyones opinion of using a physical fax machine with passthru via G711 or sticking with a regular analog line from Telco. T38 isn't available from my ITSP. I personally have had mostly good (98%) results with passthru via G711, but wanted to get the community's opinion if given the option. If I go passthru, thinking of spa3102 or something to serve as the ATA. Thanks for any recommendations.
paolo bevilacqua
I would not recommend passthrough, but T.38 exclusively. If your ITSP doesn't support it, switch to another.
OK. Do you have any recommended providers? I know there are quite a few of them out there with pricing all over the place.
