Could you be more specific concering the Cisco Equipment that you use, for example is it CUCM or CUCMExpess? Also, what kind of equipment you use to connect with the Telephony Provider (CUBE maybe?).
Following this information, some debugging commands will help to identify the cause of your dropped calls,
G
Hope the above helps,
gsotirop
