DS1 SVPRI Migration
opnineopnine
I have a customer with a  DS1 SVPRI and I have to migrate it from one Telco to an other Telco, we will have the same numbers. The voice gateway is configured via mgcp, my question is, if I will get the same numbers, what changes should I do in the voice-gateway and in the CUCM.
Thanks.
You might want to check the PRI protocol type in case the 2 Telco's use different switches.  Lucent vs. Nortel.
I have the hold device 2911 with mgcp. And I don't have any dial-peer and stuff like that.
thanks.
