IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5916 Views
  • 14 replies
I am trying to call from xxxxx to 0 (Operator). When I am only dialing 0 its taking 30 seconds to transfer. In route pattern  I have defined Called Transformation Mask "00000" now call is going OK  without any delay but on phone display its showing "...
No Ni by Level 1
  • 256 Views
  • 2 replies
In the context of a CUBE, I know that transcoding and DTMF signaling changes wil invoke DSP resources.  I also assume that stream splitting for call recording applications will also use DSP's. Are there any other CUBE configurations that will require...
Hello All, Is this the right format for a SRST dial-peer for international calling? It should match 011 and any number of digits then prefix the 011 on those digits correct? Because a dial-peer does not send matched digits? Thanksdial-peer voic...
steigja by Level 3
  • 2084 Views
  • 6 replies
Resolved! training
Hi everyone,anybody could recommend me a good trainig (books, web) about CUCM (callmanager, unity, presence...etc)???, i am very interested in it, i need for my actual job.thanks Anna.
ciscoceci by Level 1
  • 595 Views
  • 3 replies
Hi, I have uploaded devicepacks according to their version respectively, phones are registered in cucm working perfectly, but when we trying to go on phone main page from subcriber, it gives following error.Unmapped Exception /usr/local/cm/db/xml/xml...
