03-24-2011 09:56 AM - edited 03-16-2019 04:08 AM
We have a 2821 ISR and want to set up conferencing. When I go to setup sessions I get 0-0 and understand this means I'm out of DSP. So, I've found that it looks like the 2821 will hold 3 modules so if I just drop another PVDM2-16 in will it work? Is there a limit to how big of a PVDM2 you can put in a slot? Does it only have to be PVDM2-16 or could I add a PVDM2-32?
Thanks!
CPI#sh inven
NAME: "2821 chassis", DESCR: "2821 chassis"
PID: CISCO2821 , VID: V07 , SN: FTX1415AHRV
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot
0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC14232C1U
NAME: "3rd generation two port EM voice interface daughtercard on Slot 0 SubSlot
1", DESCR: "3rd generation two port EM voice interface daughtercard"
PID: VIC3-2E/M , VID: V01 , SN: FOC142468KY
NAME: "3rd generation two port FXS DID voice interface daughtercard on Slot 0 Su
bSlot 2", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID , VID: V02 , SN: FOC14194Y0P
bSlot 3", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID , VID: V02 , SN: FOC14194YDR
NAME: "PVDMII DSP SIMM with Two DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SI
MM with Two DSPs"
PID: PVDM2-32 , VID: V01 , SN: FOC14106CD6
NAME: "Integrated Service Engine for Modular and Integrated Services Routers on
Slot 1", DESCR: "Integrated Service Engine for Modular and Integrated Services R
outers"
PID: NME-CUE , VID: V03 , SN: FOC14191GYP
Cisco 2821 (revision 53.51) with 763904K/22528K bytes of memory.
Processor board ID FTX1415AHRV
2 Gigabit Ethernet interfaces
24 Serial interfaces
1 terminal line
2 Channelized/Clear T1/PRI ports
1 Virtual Private Network (VPN) Module
4 Voice FXS interfaces
2 Voice E & M interfaces
1 cisco Integrated Service Engine(s)
Cisco Unity Express 7.1.7 in slot 1
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
250880K bytes of ATA CompactFlash (Read/Write)
03-24-2011 10:06 AM
Hi Preston,
Good question
Here's the scoop;
Any PVDM2 is supported in any native PVDM slot Cisco 2801, 2811, 2821, 2851, 3825, and 3845 and on NM-HDV2 (only PVDM2s are supported natively, not first-generation PVDMs)
From this good doc;
Cheers!
Rob
03-24-2011 11:30 AM
The root source of this is that we can only conference three participants right now (obviously from the built-in software bridge) and want to be able to conference more. Also, we can't see the ConfLi option on our phones (all 7940/60 series). If I put in another DSP and get the software side setup from what I've found I'll be able to conference more than 3 participants but does the ConfLi start showing up as an option on the phones?
Thanks again!
This email and any files transmitted with it may contain confidential and privileged information for the sole use of the intended recipient(s). Any review, use, distribution or disclosure by others is strictly prohibited. If you are not the intended recipient (or authorized to receive for the recipient), please contact the sender by reply email and delete all copies of this message.
