dspfarm maximum sessions question
steve.grosz
Hi there
I am trying to get a handle on how the MeetMe works.  We have the following entry on our CME system
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
conference-join custom-cptone jointone
conference-leave custom-cptone leavetone
associate application SCCP
Does this mean that we can have 4 independant sessions of MeetMe at the same time?  As far as I know we just have 1 call in number, if it IS possible to handle 4 different conferences at the same time, how would I configure different call in numbers?
Or am I not understanding this correctly??
13 Replies 13
Jaime Valencia
Yes, that's 4 independent sessions
You can review the config guide for your questions
ephone-dn 60 dual-line
number 8887
conference meetme
no huntstop
ephone-dn 61 dual-line
number 8887
conference meetme
preference 1
no huntstop
ephone-dn 62 dual-line
number 8887
conference meetme
preference 2
no huntstop
ephone-dn 63 dual-line
number 8887
conference meetme
preference 3
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1011144
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Hmmmmm, I can't view that document for some reason.......
Hi Steve,
You should be able to if you remove "/partner" from the URL.
Like Jaime rightfully pointed out, you can have 4 seperate meet-me conference numbers configured for the config you shared.
HTH.
Harmit.
Harmit,
What URL are you referring to?
Steve, the one Jaime gave you which you said you couldnt open :-)
Here you go:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1011144
Harmit.
Gotcha!   Thanks
So here we have our config:
ephone-dn  110  dual-line
number 5555
name MeetMe
conference meetme
no huntstop
ephone-dn  111  dual-line
number 5555
name MeetMe
conference meetme
preference 1
no huntstop
ephone-dn  112  dual-line
number 5555
name MeetMe
conference meetme
preference 2
          no huntstop
ephone-dn  113  dual-line
number 5555
name MeetMe
conference meetme
preference 3
no huntstop
ephone-dn  114  dual-line
number 5555
name MeetMe
conference meetme
preference 4
no huntstop
ephone-dn  115  dual-line
number 5555
name MeetMe
conference meetme
preference 5
          no huntstop
ephone-dn  116  dual-line
number 5555
name MeetMe
conference meetme
preference 6
no huntstop
ephone-dn  117  dual-line
number 5555
name MeetMe
conference meetme
preference 7
The number is always the same, 5555, but if we can actually have different conference calls going at the same time, we only have the one external number..... its like 333-3155.......  if we can have 4 differenct conference calls going at the same time, how can I assign 3 new external phone numbers to the MeetMe system??
yahsiel2004
Level 7
Level 7
Steve,
If you only have 1 MeetMe number configured than you can only have 1 MeetMe conference regardless of how many conferences you have on the CME router configured. Also as a side note if you don't need to support all the codecs you have configured I would remove them and restrcuture your DSPFARM as it would allow you to have more participants in a conference. Example below:
Example 1:
The configuration below with 4 session would only allow 8 - 16 participants because you have G729 configured
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 4
Example 2:
The configuration below will allow (depending on the DSP you have) 4 sessions with 8 - 32 participants because only G711 is configured.
codec g711ulaw
codec g711alaw
maximum sessions 4
maximum conference-participants 32
Hope I didn't confuse you...
Yosh
HTH Regards, Yosh
Ok I stand corrected I completely ignored the fact that you are running CME... So you can have mulitple conferences with one number as Jaime mentioned above.
Yosh
HTH Regards, Yosh
So here is our inventory, what codec would you suggest???
PID: CISCO3825         , VID: V07, SN: FTX1406A0R7
NAME: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-1MFT-T1/E1 - 1-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-1MFT-T1/E1  , VID: V01 , SN: FOC11153MBD
NAME: "3rd generation two port FXS DID voice interface daughtercard on Slot 0 SubSlot 1", DESCR: "3rd generation two port FXS DID voice interface daughtercard"
PID: VIC3-2FXS/DID     , VID: V03 , SN: FOC15452LPP
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64          , VID: V01 , SN: xxxxxxxxxxx
NAME: "NM-CUE-EC on Slot 1", DESCR: "NM-CUE-EC"
PID: NM-CUE-EC         , VID: V03, SN: xxxxxxxxxxx
NAME: "40GB IDE Disc Daughter Card on Slot 1 SubSlot 0", DESCR: "40GB IDE Disc Daughter Card"
PID:                   , VID:    , SN: xxxxxxxxxxxx
yahsiel2004
Level 7
Level 7
Steve,
If you're not using G729 on your network than I would suggest using G711 on the DSPFARM. If you want to allow up to 32 participants on a conference make sure you put the "maximum conference-participants 32" command on the DSPFARM. Please note that the amount of conference participants you allow will affect the amount of conference session you can configure on the DSPFARM.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeconf.html#wp1010505
Yosh
Yosh
HTH Regards, Yosh
I checked the config on the router, and didn't see a reference to G729 anywhere but in the DSPFARM.......is there somewhere else I need to look for it to see if G729 is being used??
VoIP dial-peers are G729 by default so you might want to make sure that you set the codec to G711. Also if you have integrated any other applications with CME, verify that it doesn't require G729. If you configure the DSPFARM for G729 only the worste case scenerio would be that you would need to initiate a transcoder if a caller entering the conference is using G729.
Yosh
HTH Regards, Yosh
