DTMF is not working from PSTN to CUC
ali nasser
Dears,
I'm having an issue with DTMF from the PSTN to CUC. I tried all the changes as per the community, but no luck.
The integration is SIP between the CUC and CUCM.
Call Flow:
ISP---->CUBE(SIP)-----> CUCM(SIP)------>CUC (SIP).
here are the dial-peers;
dial-peer voice 110 voip
description Calls in primary CUCM
destination-pattern 2...
session protocol sipv2
session target ipv4:172.16.65.12
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 11 voip
description outbound to STC
translation-profile outgoing PSTN-OUT
destination-pattern 905........
session target dns:fmc.stc.com.sa:5060
voice-class sip dtmf-relay force rtp-nte
voice-class sip profiles 21
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
dtmf-relay rtp-nte
codec g711alaw
no vad
dial-peer voice 1 voip
description inbound from STC
translation-profile incoming PSTN-IN
session target ipv4:10.154.15.25
incoming called-number +9661T
dtmf-relay rtp-nte
codec g711alaw
no vad
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
localhost dns:fmc.stc.com.sa
midcall-signaling passthru
sip-profiles 21
BR
19 Replies 19
Hi @ali nasser,
How has it gone with this? Have you tested with the suggested changes that I made a few days ago? Apart from them I would also recommend you to add this to you configuration.
voice service voip
 ip address trusted list
  ipv4 172.16.65.11
  ipv4 172.16.65.12
  ipv4 172.16.65.13
  ipv4 10.154.15.25
 no allow-connections h323 to h323 !not needed as you do SIP 2 SIP
 no allow-connections h323 to sip !not needed as you do SIP 2 SIP
 no allow-connections sip to h323 !not needed as you do SIP 2 SIP
 no h323 !not needed as you do not use H.323
Response Signature
Hi @Roger Kallberg
Thanks for your email.
I'm waiting to have access to the device, it will be on Monday. i will update if this works. Also, the dtmf is not working even if you call a company with IVR.
BR
Try to activate the "Media Termination Point Required" on the sip trunk that points to the CUBE.
That should not be needed and if it is then it's IMHO a tell sign that something is wrongly configured.
Response Signature
Hi ,
Can you please activate a debug voip ccapi inout and a debug voip rtp sess name place a call to VM and post the result?
Carlo
Please rate all helpful posts "The more you help the more you learn"
