DTMF tones are not recognising
Devansh
Hi All,
Issue
When users dials from cisco IP phone to third party contact center IVR menu,The DTMF tones are not getting recognise.
But when i dial from mobile phone it is working.
Call Flow
CUCM --> H323 gateway --> PSTN
The inbound Dial Peer on H323 gateway is
dial-peer voice 10000 voip
translation-profile outgoing JEFES
preference 2
destination-pattern 9[4-6]..
session target ipv4:10.66.64.54
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw
fax rate disable
Outgoing dial Peer
dial-peer voice 10100 pots
tone ringback alert-no-PI
translation-profile outgoing SALIDA
preference 2
destination-pattern 0T
fax rate disable
direct-inward-dial
port 0/0/0:15
forward-digits all
5 Replies 5
Suresh Hudda
Which phone (model) you are using ?
Refer below thread, it may help you in this scenario.
https://supportforums.cisco.com/discussion/12958506/unable-select-call-inputs-cisco-ip-phone-during-call
Suresh
We are using 7961.
Okay, have you tried to change dtmf type as suggested in given supportforums link ?
Please attach below debug logs from h323 gateway.
debug voip rtp session named-event
Suresh
Suresh,
We are not going to get anything from this debug because OOB DTMF is not carried in rtp.
Karunka,
Can we have the following please
debug voip ccapi inout
debug h225 asn1
debug h245 asn1
Please rate all useful posts
Hi all,
please find attached logs
Calling Number 22089475
Called Number 00019196669283
