05-30-2016 12:58 PM - edited 03-17-2019 07:04 AM
Hello Folks,
Need your help with some weird problem.
Setup is like below,
IPPhone -- CUCM ---SIP trunk ----Gateway ---E1---Serivce Provider.
We have an issue saying the DTMF is intermittently working on outbound calls. Calling a certain gets connected to a IVR and pressing a access code doesn't work at times. Same location and same phone.
Could someone help me how to trouble shoot this problem .
Sanjay
05-30-2016 06:59 PM
Hi Sanjay,
If it is intermittent then your SIP
What
06-02-2016 02:19 AM
Hello Deepak,
Thank you for your suggestions.
Will check and let you know. Thanks
Sanjay.
06-02-2016 01:38 PM
I had a similar issue to this a while ago, some outbound calls were hitting the default dial-peer, once i got all calls to use the correct dial-peer then it resolved my issue.
You can use either show voice call summary or show voice call status (can't remember which one it is) to identity easily identify which dial-peer is being used on the active call.
Richard
