12-20-2010 02:30 AM - edited 03-16-2019 02:30 AM
Would like to know how to create a dummy extension number but able to register with the cisco callmanager.
Purpose of creating it is for call forward all to another number.
12-20-2010 02:48 AM
There is no special procedure to create a dummy extension number (DN) on Call Manager.
Just create an extension that is not used in your Call Manager and eventually put on the DN description "Dummy Extension"
I hope it helps,
German
12-20-2010 04:44 AM
Hi Alan,
Just to add a note to the good tips from German (+5 German)
One way to create a "Dummy" or "Virtual" number in CUCM is
create it as a CTI-RP (CTI-Route Point.) When you create a
CTI-RP you will be able to set a CFWD on the DN page
Cheers!
Rob
04-26-2023 05:54 AM
You can just create translation pattern (with dummy number) and then in called party field you enter number you want to forward to.
04-26-2023 07:51 AM
Why are you responding to a 13 years old post? That just resurface it at the top of the list and clutters the community.
05-23-2023 04:38 AM
Because I was trying to accomplish what OP was trying to do, saw solutions, tried them, they did not work, then I tried my "own" solution, it has worked so I figured out it might be helpful for somebody else as well.
