Duplex audio problem with 7975 when used as speakerphone
hypnotoad
Level 3
Level 3
Hey everyone,
I'm having a problem that I hpe can be fixed. We are having duplex audio problems when using a 7975 in speaker phone mode. For example; we have a call to out outside party and the speaker is on. We can hear the other party but they cannot hear us until they stop talking for a moment. If they don't stop speaking you cannot interupt them. I know there is a mic in this phone - that is not it. It is a one way audio issue if that makes sense. Two way coversations work perfectly if the user picks up the handset or uses a headset.
SCCP protocol
CallManager 7.1.3
MGCP gateway
G711 codec
Any ideas?
6 Replies 6
Gajanan Pande
Could you please provide firmware version in the phone ?
Is it the issue with just one 7975 or multiple/all ?
Thx
GP.
The problem is with all of the 7975 phones. Or it is with the four or five we've tested.
The firmare is SCCP75.8-5-2SR1S.
This problem may extend to my 7965s and 7945s as well. I need to test.
I was thinking that there might be a setting somewhere that is set wrong. Maybe a gateway setting? Perhaps VAD? I'm just spitballing here.
--Patrick
Patrick, if that is the case with multiple 7975's, I would start with upgrading their firmware to latest. Your firmware is 9 release older. To rule out any bugs that might be causing it, the simplest thing we can do is keep them updated & then start looking elsewhere if it doesnt fix such issues. From my past experience, it did help.
If the issue was with one/two 7975s, I'd have looked into it's defective microphone & get it RMAed.
Lemme know how it goes.
GP.
I will upgrade to the latest firmware forst thing tomorrow and do some testing. I just looked at the download site. I am way out of date.
--Patrick
Sounds good, pls lemme know how it goes.
GP.
I still haven't had user feedback on this. I'll bother them Monday or try to find a 7975 to do my own testing. More later.
--Patrick
