DX Individual Phone Upgrade
JustForVoice_2
Level 4
Level 4
I want to updarade a particular DX 80 phone. I have CUCM 11. I downloaded the Firmware file. the file contains 3 files: 1 .load and 2*.mlo files. I can upload the .load and the one of the .mlo files (bundle1). but I can not add the seconde sys1.dx80. I got the following error:
Secure Connection Failed
The connection to the server was reset while the page was loading.
10 Replies 10
Manish Gogna
Its a known bug
https://tools.cisco.com/bugsearch/bug/CSCuw28887/?reffering_site=dumpcr
Unable to upload large files using CUCM TFTP File Management
CSCuw28887
Description
Symptom:
Uploading a large file (over 250 MB) via TFTP File Management in CUCM OS Administration will fail. The process will time out with no error given.
This is easily reproducible using any CUCM version.
Conditions:
Per the developers, there is a 250 MB upload limit when using TFTP File Management.
Workaround:
Manually upload large files to CUCM TFTP via root using SFTP or SCP.
Note: This requires TAC assistance.
Please contact TAC.
Manish
Thank you for help, can I know how to manually upload large files to CUCM TFTP via root using SFTP or SCP.
Root access is available to TAC engineers , you need to open a TAC case.
Manish
Thank you
Gordon Ross
Level 9
Level 9
Why not just use the COP file to install the firmware via normal SFTP upgrade process? I installed the latest DX Series firmware cop  (1.3GB) using this method without issue.
GTG
Please rate all helpful posts.
I just want to test the upgrade on one DX, I do want to change the load for all
In which case, once the COP has installed, change the defaults back to the previous and manually set the one you want. I do this all the time without problems.
GTG
Just to make sure, no need to restart the cluster after installing the COP, I have to install in TFTP servers only and restart the TFTP servers only. No need to install on PUB and SUBs and restart the cluster, only tftp services?
*IF* a COP is being installed to add firmware ONLY (i.e. not to add support for a new device type) then you are correct.
It is when you install a COP on the publisher that changes are made to the database. (Either changing the device defaults or adding support for a new device)
GTG
DX 80 is already added to my CUCM, all waht I want to do is to change the firmware
