DX80 ANDROID TO CE CLOUD REGISTRATION
Siva chinap
Level 5
Level 5
We have old DX80 Endpoint running on Android Platform, When i try to convert CE, I could not find images in Download.
I need to confirm, Will this device supported and need the supported image for conversion.
Will it support registered over the Webex cloud?
Nithin,
I could not able to download Conversion the images it shows deferred, Can you give me downloadable image for Android to CE conversion and After conversion will these device supports cloud.
Use The Cisco Cloud Upgrader and it  will install Collaboration Endpoint (CE) software version CE9.10.0.  use the below link.
https://upgrade.cisco.com/DX
Response Signature
Ashish Patel
Look at upgrade.cisco.com. Advisable to buy support on the device if you haven't got it through a partner.
Response Signature
