11-24-2009 10:44 PM - edited 03-15-2019 08:36 PM
Hi - I think i have (at last) got my head around the theory of the new dial plan aproach using +E.164 dialling, globalized and localized routing; but have a couple of question marks around how this ties in with a the phone DN and the Directory in deployment:
As we globalize on-net calls from abbreviated extensions e.g. dialling 51111 on-net, translates this called number to the full +E.164 using a CSS, should we now address on-net endpoints with their DN as the full +E.164 number? In respect to this, what should users be made aware of as their internal extension? Should this still be, for example, internal 5 digit and let the CSS take care of ringing the +E.164 internal endpoint . Also what is best practice for the corporate directory? should the phone number field be populated with the full +E.164 or the abbreviated extension?
Any thoughts on this would be greatly appreciated.
thks
Brian
Solved! Go to Solution.
12-08-2010 12:10 PM
The answer differs for each product.
Unity Connection:
Contact Center Express:
Emergency Responder
You're on your own on this one. We use 911 Enable because CER is useless for 802.11-based deployments (which most of our deployments large enough to necessitate CER have).
10-15-2012 08:42 PM
Hi Jonathan,
We are having few issues when using E164 dialing. Customer site contains only 7940 ip phone model and it doesnt support + sign and the problem they are facing when they do a call back from the phone's directories and also dialing the corporate directory number which is also starts with + sign. When the phone dials any number which starts with +, it's not matching the either tranlsation pattern \+.! or the internal directory number (e164 format). I've read in some forms that we can use calling party transformation for call back as a work around but no detail explanation. Could you help us to find a workaround for this issue.
Shine
10-16-2012 04:13 AM
I'm almost positive that if you apply a Calling Party Transformation CSS to the device of a 7940/7960 it will strip the plus from the missed and received calls directory. I don't have a 7940 handy to test this with but have done it in the past. I recognize this differs from newer phones who do not act the same way with CgPI transformations on the device. I believe that the CgPI transform adds an extra field in the SCCP packet to show the pre-transformed value but the 7940/7960 doesn't support this so it just takes transformed value (i.e. after stripping the plus). Try it and see.
As for the corporate directory: You're screwed here. Deploy Jabber and do deskphone control.
Please remember to rate helpful responses and identify helpful or correct answers.
