E 164 dialing local numbers
rhegde
I have a situation where I am sending the local US calls in + E 164 (1+10 digits) format but the service provider expects to receive only 10 digits. If I send the calls to him in 11 digits we get a message that, send only 10 digits. How do we over come this issue ?
This may not be unique situation as some states ,  we need to send 10 digit for local calls and 11 digits for toll calls with the same area code.
Rav
Jonathan Schulenberg
You need to use transformation patterns on the off-net gateway/trunk to localize the values. If you have an NPA requiring 10-digit subscriber dialing, you can do it on the IOS gateway using translation profiles if you prefer. Typically this isn't feasible if you're in an NPA that offers seven-digit subscriber dialing.
Cisco SRND:
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/dialplan.html#wp1172104
NANPA NPA Tool (Dialing Plan is in the lower-right of the table):
http://nanpa.com/nas/public/npa_query_step1.do?method=resetNpaReportModel
