E1 is UP, but not working
Hello Everyone,
I am having a bad time configuring a E1. Eveything seems to be fine and up, but i cannot get to make a phone call. My telco says everything is fine on their side, but I get this results on the E1 controller:
R_POTOSI#show controllers e1
E1 0/0/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is NO-CRC4, Line Code is HDB3, Clock Source is Line.
International Bit: 1, National Bits: 11111
Data in current interval (195 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 5 15 minute intervals):
23 Line Code Violations, 287 Path Code Violations,
3 Slip Secs, 0 Fr Loss Secs, 2 Line Err Secs, 0 Degraded Mins,
4 Errored Secs, 9 Bursty Err Secs, 0 Severely Err Secs, 1680 Unavail Secs
I read that the Line Code and Path Code Violations are due to physical line problems, but they say that everything is OK since the E1 is UP. Are they right? If not, how can I prove them wrong.
Thanks in advance for the help
   Cause i = 0x828100000000 - Unallocated/unassigned number
tells you the dialed number is invalid.
Chris
13 Replies 13
Chris Deren
Post your config of the controller.
Chris
Hi Chris, this what I'v got configured:
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
Is this a pri circuit?  Can you post "sh isdn status"?
Since you are using MGCP do you have MGCP configured on the GW and in CUCM?
Chris
Yes, this is a PRI circuit. MGCP is properly configured on CUCM. I have a couple of FXOs that are working just fine.
Router#show isdn status
Global ISDN Switchtype = primary-net5
%Q.931 is backhauled to CCM MANAGER 0x0003 on DSL 0. Layer 3 output may not apply
ISDN Serial0/0/0:15 interface
        dsl 0, interface ISDN Switchtype = primary-net5
        L2 Protocol = Q.921 0x0000 L3 Protocol(s) = CCM MANAGER 0x0003
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask: 0xFFFF7FFF
    Number of L2 Discards = 0, L2 Session ID = 28
    Total Allocated ISDN CCBs = 0
Bruno
Cool, can you get "debug isdn q931" for the failed call?
Chris
I've got the debug Chris:
//70/CCB6379E8021/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23B93650, callID=0x46, disp=0, digit_event=0x1, enable=TRUE, consume=FALSE)
001707: Jul 11 23:09:40.750: //70/CCB6379E8021/CCAPI/cc_api_call_report_digits_done:
   Enabled=TRUE, Disposition=0x0, Interface=0x23B93650, Call Id=70
001708: Jul 11 23:09:40.750: //70/CCB6379E8021/CCAPI/cc_api_call_report_digits_done:
   Call Entry(Initial Digit Timeout=4000(ms), Inter Digit Timeout=4000(ms))
001709: Jul 11 23:09:40.754: ISDN Se0/0/0:15 Q931: TX -> SETUP pd = 8  callref = 0x0007
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0xA9839F
                Exclusive, Channel 31
        Calling Party Number i = 0x0081, '0500'
                Plan:Unknown, Type:Unknown
        Called Party Number i = 0x80, '6228444'
001710: Jul 11 23:09:40.838: ISDN Se0/0/0:15 Q931: RX <- CALL_PROC pd = 8  callref = 0x8007
001711: Jul 11 23:09:40.846: ISDN Se0/0/0:15 Q931: RX <- DISCONNECT pd = 8  callref = 0x8007
001712: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/ccCallReportDigits:
   (callID=0x46, digit_event=0x0, enable=FALSE, consume=FALSE)
001713: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/ccCallReportDigits:
   Enabled=TRUE, Call Id=70
001714: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/cc_api_call_report_digits_done:
   (vdbPtr=0x23B93650, callID=0x46, disp=0, digit_event=0x0, enable=FALSE, consume=FALSE)
001715: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/cc_api_call_report_digits_done:
001716: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/cc_api_call_report_digits_done:
001717: Jul 11 23:09:40.934: //71/CCB6379E8021/CCAPI/ccGetCallStatistics:
   Call Stats=0x210B3B58, Call Id=71
001718: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/ccConferenceDestroy:
   Conference Id=0x1D, Tag=0x0
001719: Jul 11 23:09:40.934: //70/CCB6379E8021/CCAPI/ccConferenceDestroy:
001720: Jul 11 23:09:40.934: confID:0x1D; callEntry1 callID1:0x46, type:6; callEntry2 callID2:0x47, type:9
Thanks for the help
Bruno,
The status and config look correct
debug isdn q931 and make a test call
post the output of the debug
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
Hello Alex, I've just posted the debug output on the question above.
The calling number is 0500 (that is actually translated to 2611-0500), and the called number is 6228444.
Bruno
Chris
Chris, is this because there's something missing on my config or because the Telco is missing something?
Is this in inboud or outboudn call?
Chris
Hello Chris, this is and outbound call.
Bruno
My problem has been solved. The Telco has corrected something, they wouldn't say what was it.
Anyway, thanks for the help Chris and Alex.
Bruno
