E1 ISDN setup Claro-Telmex in Colombia
Miquel Bover
Hello Team,
I have to setup an ISDN E1 (30 channels) in Colombia, the Service Provider is Claro (Telmex). I have doubs regarding the ISDN switch-type to use.
Is there anyone who have a ISDN E1 setup for Claro in Colombia?
controller E1 0/1/0
framing no-crc4
clock source line primary
line-termination 75-ohm
pri-group timeslots 1-31
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn switch-type ????????
isdn incoming-voice voice
isdn negotiate-bchan
no cdp enable
Thank you in advance
Best regards!
Miquel Bover
mtorres.plannet
Hello Miquel,
Did you find support with this issue? I have the same case right now.
Best regards,
Maricela Torres.
Please, see below the right setup:
controller E1 0/1/0
  no ip address
  encapsulation hdlc
  isdn switch-type primary-5ess
  no cdp enable
COBOGVGW01#sh controllers E1 0/1/0
E1 0/1/0 is up.
Applique type is Channelized E1 - balanced
No alarms detected.
alarm-trigger is not set
Framing is crc4, Line Code is HDB3, Clock Source is Line Primary.
International Bit: 1, National Bits: 11111
Data in current interval (34 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
