E1 PRI Group Timeslots
Im triying to configure a E1 with the PRI group timeslots command as follow:
controller E1 0/0/0
    line-termination 75-ohm
    pri-group timeslots 1-30
Then, I'm using interface serial0/0/0:15 to configure signalling.
Right know everything is working fine, but I'm a little confused.
As fas as I know, E1 have 32 timeslots or channels (1 to 32), where the fisrt channel is TS0 and the last one is TS31. Signalling should always go on channel 16, which is TS15.
My question is, in the controller configuration, shouldnt be "pri-group timeslots 1-31" instead of 1-30? ...
If I have pri-group timeslots 1-30 does it means that I only configured 29 voice channels? because TS15 is not going to be usefull
When I do a show voice port summary, I still see 30 channels =S
                                           IN       OUT
PORT            CH   SIG-TYPE   ADMIN OPER STATUS   STATUS   EC
0/0/0:15        01  isdn-voice  up    dorm none     none     y
0/0/0:15        02  isdn-voice  up    dorm none     none     y
0/0/0:15        03  isdn-voice  up    dorm none     none     y
0/0/0:15        04  isdn-voice  up    dorm none     none     y
0/0/0:15        05  isdn-voice  up    dorm none     none     y
0/0/0:15        06  isdn-voice  up    dorm none     none     y
0/0/0:15        07  isdn-voice  up    dorm none     none     y
0/0/0:15        08  isdn-voice  up    dorm none     none     y
0/0/0:15        09  isdn-voice  up    dorm none     none     y
0/0/0:15        10  isdn-voice  up    dorm none     none     y
0/0/0:15        11  isdn-voice  up    dorm none     none     y
0/0/0:15        12  isdn-voice  up    dorm none     none     y
0/0/0:15        13  isdn-voice  up    dorm none     none     y
0/0/0:15        14  isdn-voice  up    dorm none     none     y
0/0/0:15        15  isdn-voice  up    dorm none     none     y
0/0/0:15        17  isdn-voice  up    dorm none     none     y
0/0/0:15        18  isdn-voice  up    dorm none     none     y
0/0/0:15        19  isdn-voice  up    dorm none     none     y
0/0/0:15        20  isdn-voice  up    dorm none     none     y
0/0/0:15        21  isdn-voice  up    dorm none     none     y
0/0/0:15        22  isdn-voice  up    dorm none     none     y
0/0/0:15        23  isdn-voice  up    dorm none     none     y
0/0/0:15        24  isdn-voice  up    dorm none     none     y
0/0/0:15        25  isdn-voice  up    dorm none     none     y
0/0/0:15        26  isdn-voice  up    dorm none     none     y
0/0/0:15        27  isdn-voice  up    dorm none     none     y
0/0/0:15        28  isdn-voice  up    dorm none     none     y
0/0/0:15        29  isdn-voice  up    dorm none     none     y
0/0/0:15        30  isdn-voice  up    up   none     none     y
Thank you
2 Accepted Solutions
David,
Imagine you had only bought 20 usable channels from your service provider
You would configure like this:-
controller E1 0/0/0
pri-group timeslots 1-21
Timeslot 16 is as you know for signalling so we need to add an additional timeslot to compensate for timeslot 16
Usable channels 1-15, 17-21 = 20
So for the full 30 usable channels:-
controller E1 0/0/0
This link may help you
http://www.cisco.com/en/US/docs/ios/12_2/dial/configuration/guide/dafchant_support_TSD_Island_of_Content_Chapter.html#wp1001062
Hope this helps
Regards Alex
Regards, Alex. Please rate useful posts.
Hi David,
Regarding your query,
When I do a show voice port summary, I still see 30 channels =S "the sequence then voice-port 16 you can not see, so total number of B channels is still 29.
you will always see the (number of channels -1 ) you have configured in output of "show voice port summary".
Nishant Savalia
Regards, Nishant Savalia
7 Replies 7
Jaime Valencia
PRI provides a varying number of channels depending on the standards in the country of implementation. In North America and Japan it consists of 23xB (B channels(be/s). In Europe and Australia it is 30xB + 1xD on an E1 2.048 Mbit/s. One timeslot on the E1 is used for synchronization purposes and is not considered to be a B or D channel.
http://en.wikipedia.org/wiki/Primary_Rate_Interface
java
if this helps, please rate
Hi Jaime,
I know that... I also know how the signalling works
My question is about the timsslots when configuring the pri-group for E1 ISDN PRI
And that snip answers your questions. 32 channels total, only 30 B channels, 1 D, one for sync
How many B channels you'll use is what you configure as pri-group timeslots.
java
So what will be the difference between:
and
pri-group timeslots 1-30 ?
 E1 should give me 30 channels anyway
1-31 should be used with NFAS, but it's rare to see that. You usually see that with T1s.
java
David,
controller E1 0/0/0
controller E1 0/0/0
Hope this helps
Regards Alex
Hi David,
Nishant Savalia
