07-09-2008 03:15 AM - edited 03-15-2019 11:50 AM
When i navigate to network settings->ip address there's no edit button displayed. When i press " * * # " The "EDIT" button appears, but it's grayed (disabled). How to enable it? Thank you.
07-09-2008 03:26 AM
Set DHCP off in the same menu. You should then be able to configure IP address.
Please rate post if it helps!
07-09-2008 03:53 AM
Sorry, found the solution myself. You should disable dhcp from the same menu before the edit button becomes enabled.
09-13-2023 06:39 AM
In may case the 7911 getting wrong vlan , I navigated to Admin VLan and press **# and it allowed me to enter vlan
