efxs ports
Pawan Arora
What are efxs voice ports?
Aaron Harrison
I think what you are referring to are the ports that CME uses to reference each ephone.
For example, on some command output you will see ports like 50/0/1 - this is basically ephone-dn 1.
Internally, CME assigns dial-peers to each ephone-dn, so for example ephone-dn 5 with number 55 might be 'destination-patter 55',pointed at 'port 50/0/5'.
I think you can see this by doing 'show telephony-service dial-peer' or something similar.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Aaron Harrison
Aaron
thanks Aaron for the information, I saw a configuration on SRST router which has some efxs ports. I think those ports are for ephone dn's.
Yep - same same. See 'show call-manager-fallback dial-peer'  in that case.
Aaron
Please rate responses if useful and mark answered if appropriate...
shalushar
Level 7
Level 7
Hi Pawan,
Read the below link
http://www.ciscopress.com/articles/article.asp?p=401648
Hope this helps.
Tx,
Shalu
