ehwic vdsl2-ciro
nettuno8_20111
hi I have a 2901 CME 12.0 router version 15.7 I have a problem with an ehwic va-dsl-m, I connected the telephone cable but it doesn't connect with the provaider        !
controller VDSL 0/0/0
description VDSL+2-ADSL+2
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0/1
description router-voice to router-isp
ip address 192.168.0.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1.15
description VOIP-SIP-SCCP
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
interface ATM0/0/0
no ip address
shutdown
no atm ilmi-keepalive
interface Ethernet0/0/0
no ip address
interface Ethernet0/0/0.835
encapsulation dot1Q 835
ip nat inside
ip virtual-reassembly in
pppoe enable group global
pppoe-client dial-pool-number 10
interface Dialer1
mtu 1492
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 10
ppp chap hostname aliceadsl
ppp chap password 0 aliceadsl
ppp pap sent-username aliceadsl password 0 aliceadsl
ip forward-protocol nd
ip http server
no ip http secure-server
ip dns server
ip nat inside source list 100 interface Dialer1 overload        router-voice(config)#do show ip interface brie
Embedded-Service-Engine0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/0 unassigned YES NVRAM administratively down down
GigabitEthernet0/1 192.168.0.1 YES NVRAM up up
GigabitEthernet0/1.15 192.168.15.1 YES NVRAM up up
ATM0/0/0 unassigned YES NVRAM administratively down down
Ethernet0/0/0 unassigned YES NVRAM up down
Ethernet0/0/0.835 unassigned YES unset up down
Dialer1 unassigned YES NVRAM up up
NVI0 192.168.0.1 YES unset up up
Virtual-Access1 unassigned YES unset up up
2 Accepted Solutions
acampbell
You are missing a basic element of the PPPoE configuration.
You need to set the "bba" group "global£ before the ethernet can use it.
bba-group pppoe global **** YOU NEED THIS FIRSTLY ****
ip nat inside
pppoe enable group global ***** IT TIES TO THIS *****
Regards, Alex. Please rate useful posts.
Hi, I solved the problem: I hadn't installed the firmware for the ehwic-va-dsl-m module in the flash memory and then configured it in the ehwic-va-dsl-m module with the appropriate firmware command xxxxxxxxx
acampbell
ip nat inside
