04-17-2014 03:27 AM - edited 03-16-2019 10:29 PM
Hi all, I was wondering how everybody configures their CUCM with regards to emergency services, at the moment if a user dials 999 and hangs up we would get the emergency services turn up at our head office and not where the user made the call from, we need to have the location that the call was made from presented to the emergency services.
Cisco has EOS their Emergency Responder and I can not seem to find a suitable solution or work around, what is the most common solution?
Thanks all
Martyn
Solved! Go to Solution.
04-17-2014 06:32 AM
Hi Martyn,
I believe that only the 8.0 - 8.7 versions (and earlier) have been EoL/EoS by Cisco and that the newest 10.0 version is the recommended replacement
CER End of Life notices;
http://www.cisco.com/c/en/us/products/unified-communications/emergency-responder/eos-eol-notice-listing.html
CER 10.x
http://www.cisco.com/c/en/us/products/collateral/unified-communications/emergency-responder/data-sheet-c78-729891.html
Cheers!
Rob
04-17-2014 06:32 AM
Hi Martyn,
CER 10.x
Cheers!
Rob
