Empty RTP stats for successful calls in "show call active voice"
ua_minjust
All RTP-relates counters are zero even for successful calls. How can I fix this?
# show call active voice
GENERIC:
SetupTime=120072290 ms
Index=1
PeerAddress=908112937676
PeerSubAddress=
PeerId=76763
PeerIfIndex=71
LogicalIfIndex=0
ConnectTime=120072560 ms
CallDuration=00:03:32 sec
CallState=4
CallOrigin=1
ChargedUnits=0
InfoType=speech
TransmitPackets=10927
TransmitBytes=213612
ReceivePackets=8849
ReceiveBytes=176980
VOIP:
ConnectionId[0x8A2624BE 0xA85F11DF 0xBE24F8CC 0x00000000]
IncomingConnectionId[0x8A2624BE 0xA85F11DF 0xBE24F8CC 0x00000000]
CallID=459869
GlobalCallId=[0x8A26C0E6 0xA85F11DF 0xBE27F8CC 0x00000000]
RemoteIPAddress=192.169.4.17
RemoteUDPPort=15160
RemoteSignallingIPAddress=192.169.4.17
RemoteSignallingPort=5060
RemoteMediaIPAddress=192.169.4.17
RemoteMediaPort=15160
RoundTripDelay=0 ms
SelectedQoS=best-effort
tx_DtmfRelay=rtp-nte
FastConnect=FALSE
AnnexE=FALSE
Separate H245 Connection=FALSE
H245 Tunneling=FALSE
SessionProtocol=sipv2
ProtocolCallId=8A27F936-A85F11DF-BE2AF8CC-00000000@192.169.0.114
SessionTarget=192.169.4.17
OnTimeRvPlayout=0
GapFillWithSilence=0 ms
GapFillWithPrediction=0 ms
GapFillWithInterpolation=0 ms
GapFillWithRedundancy=0 ms
HiWaterPlayoutDelay=0 ms
LoWaterPlayoutDelay=0 ms
TxPakNumber=0
TxSignalPak=0
TxComfortNoisePak=0
TxDuration=0
TxVoiceDuration=0
RxPakNumber=0
RxSignalPak=0
RxComfortNoisePak=0
RxDuration=0
RxVoiceDuration=0
RxOutOfSeq=0
RxLatePak=0
RxEarlyPak=0
RxBadProtocol=0
PlayDelayCurrent=0
PlayDelayMin=0
PlayDelayMax=0
PlayDelayClockOffset=0
PlayDelayJitter=0
PlayErrPredictive=0
PlayErrInterpolative=0
PlayErrSilence=0
PlayErrBufferOverFlow=0
PlayErrRetroactive=0
PlayErrTalkspurt=0
ClockAdjustDuration=0
EarlyPacketDuration=0
LateDiscardDuration=0
SilenceDiscardDuration=0
JBuffDecreaseDuration=0
JBuffIncreaseDuration=0
OutSignalLevel=0
InSignalLevel=0
LevelTxPowerMean=0
LevelRxPowerMean=0
LevelBgNoise=0
ERLLevel=0
ACOMLevel=0
ErrRxDrop=0
ErrTxDrop=0
ErrTxControl=0
ErrRxControl=0
ReceiveDelay=0 ms
LostPackets=0
EarlyPackets=0
LatePackets=0
SRTP = off
TextRelay = off
VAD = disabled
CoderTypeRate=g729r8
CodecBytes=20
Media Setting=flow-through
CallerName=+999124581487
CallerIDBlocked=False
OriginalCallingNumber=999124581487
OriginalCallingOctet=0x11
OriginalCalledNumber=999112937676
OriginalCalledOctet=0x91
OriginalRedirectCalledNumber=
OriginalRedirectCalledOctet=0x80
TranslatedCallingNumber=999124581487
TranslatedCallingOctet=0x11
TranslatedCalledNumber=999112937676
TranslatedCalledOctet=0x91
TranslatedRedirectCalledNumber=
TranslatedRedirectCalledOctet=0x80
GwReceivedCalledNumber=+999112937676
GwReceivedCalledOctet3=0x0
GwOutpulsedCalledNumber=999112937676
GwOutpulsedCalledOctet3=0x91
GwReceivedCallingNumber=+999124581487
GwReceivedCallingOctet3=0x0
GwReceivedCallingOctet3a=0x80
GwOutpulsedCallingNumber=999124581487
GwOutpulsedCallingOctet3=0x11
GwOutpulsedCallingOctet3a=0x80
MediaInactiveDetected=no
MediaInactiveTimestamp=
MediaControlReceived=
LongDurationCallDetected=no
LongDurCallTimestamp=
LongDurcallDuration=
Username=+999124581487
Appropriate voice dial peer :
        peer type = voice, system default peer = FALSE, information type = voice,
        description = `*** Redirection outgoing LEG ***',
        tag = 76763, destination-pattern = `99112937676',
        voice reg type = 0, corresponding tag = 0,
        allow watch = FALSE
        answer-address = `', preference=0,
        CLID Restriction = None
        CLID Network Number = `'
        CLID Second Number sent
        CLID Override RDNIS = disabled,
        rtp-ssrc mux = system
        source carrier-id = `', target carrier-id = `',
        source trunk-group-label = `',  target trunk-group-label = `',
        numbering Type = `unknown'
        group = 76763, Admin state is up, Operation state is up,
        incoming called-number = `', connections/maximum = 3/unlimited,
        DTMF Relay = enabled,
        modem transport = system,
        URI classes:
            Incoming (Request) =
            Incoming (To) =
            Incoming (From) =
            Destination =
        huntstop = disabled,
        in bound application associated: 'DEFAULT'
        out bound application associated: ''
        dnis-map =
        permission :both
        incoming COR list:maximum capability
        outgoing COR list:minimum requirement
        Translation profile (Incoming):
        Translation profile (Outgoing):
        incoming call blocking:
        translation-profile = `'
        disconnect-cause = `no-service'
        advertise 0x40 capacity_update_timer 25 addrFamily 4 oldAddrFamily 4
        mailbox selection policy: none
        type = voip, session-target = `ipv4:192.168.4.17',
        technology prefix:
        settle-call = disabled
        ip media DSCP = ef, ip media rsvp-pass DSCP = ef
        ip media rsvp-fail DSCP = ef, ip signaling DSCP = af31,
        ip video rsvp-none DSCP = af41,ip video rsvp-pass DSCP = af41
        ip video rsvp-fail DSCP = af41,
        ip defending Priority = 0, ip preemption priority = 0
        ip policy locator voice:
        ip policy locator video:
        UDP checksum = disabled,
        session-protocol = sipv2, session-transport = system,
        req-qos = best-effort, acc-qos = best-effort,
        req-qos video = best-effort, acc-qos video = best-effort,
        req-qos audio def bandwidth = 64, req-qos audio max bandwidth = 0,
        req-qos video def bandwidth = 384, req-qos video max bandwidth = 0,
        dtmf-relay = rtp-nte,
        RTP dynamic payload type values: NTE = 101
        Cisco: NSE=100, fax=96, fax-ack=97, dtmf=121, fax-relay=122
               CAS=123, TTY=119, ClearChan=125, PCM switch over u-law=0,
               A-law=8, GSMAMR-NB=117 iLBC=116, AAC-ld=114, lmr_tone=0, nte_tone=0
               h263+=118, h264=119
               G726r16 using static payload
               G726r24 using static payload
        RTP comfort noise payload type = 19
        fax rate = voice,   payload size =  20 bytes
        fax protocol = system
        fax-relay ecm enable
        Fax Relay ans enabled
        Fax Relay SG3-to-G3 Enabled (by system configuration)
        fax NSF = 0xAD0051 (default)
        codec = transparent,   payload size =  0 bytes,
        video codec = None
        voice class codec = `'
        voice class sip rsvp-fail-policy voice post-alert mandatory keep-alive interval 30
        voice class sip rsvp-fail-policy voice post-alert optional keep-alive interval 30
        voice class sip rsvp-fail-policy video post-alert mandatory keep-alive interval 30
        voice class sip rsvp-fail-policy video post-alert optional keep-alive interval 30
        text relay = disabled
        Media Setting = flow-through (voice class media 1)
        Expect factor = 10, Icpif = 20,
        Playout Mode is set to adaptive,
        Initial 60 ms, Max 1000 ms
        Playout-delay Minimum mode is set to default, value 40 ms
        Fax nominal 300 ms
        Max Redirects = 1, signaling-type = cas,
        VAD = disabled, Poor QOV Trap = disabled,
        Source Interface = NONE
        voice class sip url = system,
        voice class sip rel1xx = system,
        tvoice class sip outbound-proxy = system,
        voice class sip asserted-id = system,
        voice class sip privacy = system,
        voice class sip e911 = system,
        voice class sip history-info = system,
        voice class sip anat = system,
        voice class sip g729 annexb-all = system,
        voice class sip early-offer forced = system,
        voice class sip negotiate cisco = system,
        redirect ip2ip = disabled
        local peer = false
        probe disabled,
        Secure RTP: system (use the global setting)
        voice class perm tag = `'
        Time elapsed since last clearing of voice call statistics never
        Connect Time = 22557291, Charged Units = 0,
        Successful Calls = 1739, Failed Calls = 3, Incomplete Calls = 0
        Accepted Calls = 0, Refused Calls = 0,
        Last Disconnect Cause is "10  ",
        Last Disconnect Text is "normal call clearing (16)",
        Last Setup Time = 11404330.
        Last Disconnect Time = 11404377.
Felipe Garrido
What type of call is the output for? What's the call flow? How is the gateway configured?
-Felipe
